09-19-2021 02:04 AM
09-20-2021 08:36 AM
k_huatSince it seems to go out before 0%, I'll add to wait a few minutes after it goes out and try to turn it back on. if it does not want to turn on, plug in and charge but if it turns on again, wait for it to turn off again, start over if necessary.https://zentalk.asus.com/en/discussion/comment/186824#Comment_186824
Thank you so much!
09-20-2021 06:03 PM
FunBike31@FunBike31https://zentalk.asus.com/en/discussion/comment/186826#Comment_186826
In the latter case, if it is turned back on with 10% or more battery power when it was off long before it was 0%, this is not a good sign for the battery.
09-20-2021 11:54 PM
k_huathttps://zentalk.asus.com/en/discussion/comment/186839#Comment_186839
Thanks for the info. I tried to turn it on but it stay off, luckily. Now I get it fully charged n see if it turn off again before 0%
09-21-2021 02:37 PM
k_huatTry turning off battery care completely and let it shut down by itself.https://zentalk.asus.com/en/discussion/comment/186866#Comment_186866
After I got it charged to full (99%) n now it shutdown again at +/-20%.
Fyi, I can't get it charge until 100%, it will stay at 99% (I waited 10min), is this normal? From 0-99% it takes around 30min+ but it will stay at 99% only. I scared it would damage the phone so I decided to stop charging it after waited 10min at 99%; or should I waited until 100%?
Now again I'll see if it shutdown again at +/-20%, n will ask for help if this happen again. Thanks
09-21-2021 09:36 PM
ronald1985@ronald1985https://zentalk.asus.com/en/discussion/comment/186885#Comment_186885
Keep turning it on and leave the phone on so it completely drained of battery juice.
Once it is completely off and doesn't turn on, leave it charging to 100%.
