Huge Huge Battery Drainage
Speed_Rebirth
Model Name: Asus Rog Phone 5
Firmware Version: .86
Rooted or not: Not Rooted
Frequency of Occurrence: Once in a While
APP Name & APP Version (If your issue relates to the app): org.codeaurora.ims
Today I'm facing a huge battery drainage. I don't know the reason some app called org.codeaurora.ims is draining battery like hell 8% battery brain in 10 minutes.
Please suggest me a solution for this issue.
Please find the attachment.
20 REPLIES 20
Lord_Messi
Zen Master II
chi8104
https://zentalk.asus.com/en/discussion/comment/179712#Comment_179712
My calls and Volte is working again Thanks.
But battery drainage is still the same issue.
Org.codeaurora.ims
Android System
Android Os
These 3 applications after force stop and clear cache still are draining the battery like hell and due to which phone is getting hot.
Hope upcoming update will fix these issues soon.
Thanks For your time team.
For temporary solution try to downgrade your firmware
waxy78611
Hello, could you Please revert the speaker sound/quality back to how it was when the phone was released? It's definitely lost some volume since being updated. When you first released the Rog 5, the speakers were superb, 10/10. Please change speakers back to how they were in the first place
The should allow us to use rgb when open camera app too
Don't play play bosque
