Huge Huge Battery Drainage
Speed_Rebirth
Model Name: Asus Rog Phone 5
Firmware Version: .86
Rooted or not: Not Rooted
Frequency of Occurrence: Once in a While
APP Name & APP Version (If your issue relates to the app): org.codeaurora.ims
Today I'm facing a huge battery drainage. I don't know the reason some app called org.codeaurora.ims is draining battery like hell 8% battery brain in 10 minutes.
Please suggest me a solution for this issue.
Please find the attachment.
20 REPLIES 20
Speed_Rebirth
waxy78611
https://zentalk.asus.com/en/discussion/comment/179388#Comment_179388
No problem ☺️.
It will definitely work for you, I promise. ADB is really good. Simply uninstall that annoying app and you're good to go.
Please mark my response as solution/best answer once you're done too ☺️
Hey I tried adb uninstall.
After removing that bloatware my volte disappeared and I'm not able to make any calls neither I'm able to receive calls.
Only wifi calling is there.
Please help me out.
I don't know what relates Volte with that Bloatware org.codeaurora.ims
Please provide me a solution.
waxy78611
Zen Master I
chi8104
https://zentalk.asus.com/en/discussion/comment/179392#Comment_179392
Please help me out.
To restore the app via ADB enter this command:
adb shell cmd package install-existing org.codeaurora.ims
Once reinstalled, check if battery drain is still there.
Let me know once you have reinstalled
waxy78611
Zen Master I
chi8104
Please help me out.
Any update ? I posted 2 times how to reinstall codeaurora
Speed_Rebirth
waxy78611
https://zentalk.asus.com/en/discussion/comment/179571#Comment_179571
Thanks Again,
I got this bloatware again. But now not only this app Android System named application also draining battery.
I think I need to wait for a new FW update or I have to reset the device again. Tried battery calibration also.
I'm stucked in this battery draining process.
waxy78611
Zen Master I
chi8104
https://zentalk.asus.com/en/discussion/comment/179574#Comment_179574
Thanks Again,
Okay so are your calls working now?
Do this;
Download Gsam battery monitor from play store. Enable ADB Permission. Charge your phone to full battery. Then after you take it off charge, use it regularly & when your battery reaches 20%< take screenshot of your battery stats on Gsam battery monitor and post on here, we will see what the battery draining issue is
