Charging LED Enable Bug
chrismills83
Model Name: ROG Phone 5s Pro
Firmware Version: Whatever the latest is.
Rooted or not: No
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): Settings - Latest version
Whenever I disable the notification LED and I connect the phone to charge the master on off setting for if the LED is enabled or disabled gets enabled again on its own and stays enabled until I toggle it off again in settings. I don't know if it has any relation to using steady charging and the battery limiter set to 80%.
Unrelated comment: I would really like to see more Always On Display options, maybe even an editor to make our own? Specifically I want a monthly calendar AOD, but there isn't much to choose from with just 5 options available.
0 REPLIES 0
