08-01-2021 10:19 AM
08-01-2021 11:53 PM
jatinmuppiri17Try to disable Google Chrome. Clear cache, clear data, uninstall updates, force stop & then disable in this order.https://zentalk.asus.com/en/discussion/comment/179301#Comment_179301
Cant delete google chrome
08-02-2021 12:17 AM
waxy78611I mean what's the point of buying a flagship and not being able to use a basic app like Chrome. I don't want to switch to some other browser .https://zentalk.asus.com/en/discussion/comment/179352#Comment_179352
You can always try to use a downgraded version of chrome to see if that helps.
Alternatively, if the battery drain persists even after disabling, simply uninstall chrome via ADB
08-02-2021 12:22 AM
jatinmuppiri17Chrome seems to be working fine for everyone else. Maybe it's an app that's causing the issue with chrome. I've never had issues with chromehttps://zentalk.asus.com/en/discussion/comment/179353#Comment_179353
08-02-2021 12:29 AM
waxy78611What I think Is it's a glitch because even if I disable chrome and use other apps for instance YouTube then the chrome drain keeps increasing.https://zentalk.asus.com/en/discussion/comment/179357#Comment_179357
08-02-2021 12:49 AM
jatinmuppiri17Chrome and android system webview performs very weird at times (googled patches the excessive battery usage bug a couple of times)
- Model Name: Rog phone 5
- Firmware Version:
- Rooted or not: Not rooted
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app): Chrome
I mean I don't think I need to say anything. Chrome's literally drained half my battery
Hope someone can help me.
Even worse now
Battery drain issue on the rog 5
