Auto Hz Issue
hp9976802431
Rising Star II
When I select Auto Hz in Refresh rate settings Cannot show 144 Developer options show display rate it only shows 120 hz . Because I'm play bgmi in 90 fps game play graphic settings in Game genie setting Select auto refresh rate only show 60 Refresh Rate.But I select 120 it run .Auto Hz what's your showing display 144 or 120
11 REPLIES 11
hp9976802431
Rising Star II
See in the video
hp9976802431
Rising Star II
I checked all rog post you always commented and triggered every one.If you find this problem Solved it me
hp9976802431
Rising Star II
@FunBike31 if you find it the problem
FunBike31
Community Legend I
You do not specify the firmware version of your friend, except you are that I see in .83, I think your problem is this firmware.
But if I understood correctly, in auto it configures itself at 60 fps instead of 120 fps, so when forcing 120 or 144 in Armory Create it works I don't see the problem.
For my part, I find it stupid that he is in 120 in car even without doing anything, I find 60 much better and even 30 even better.
Apple understood it well with its latest version of high frequency screen which goes much lower when you don't need high refresh, the battery saving is enormous
hp9976802431
Rising Star II
I tried Android 11 all versions and Android 12 versions too .Why the value changes I selected value out side auto hz it show 120 frame rate but inside game game open suddenly changed 60 fps in game genie also autohz mode .I checked more rog series it's working fine but mine? Plz find the problem help to me
