Wifi Calling / VoLTE not working? Look here!
Danishblunt
Hall of Fame I
Since this varies greatly from person to person I would like to create this topic in order to make the devs figure things out easier.
Fill out the following:
Provider: TDC
Country: Denmark
Provisions:
( type in calling app: #*#4636#*# for getting the information )
VoLTE: Yes
Video Calling Provisioned: Yes
WiFi-Calling: Yes
What doesn't work:
VoLTE doesn't work, Wifi Calling works fine.
@Mattias_ASUS You can tell the devs to look for this topic to fix further VoLTE issues. Some cant use Wifi Calling, others have VoLTE enabled in settings but doesn't actually work on their phone.
22 REPLIES 22
Danishblunt
Hall of Fame I
eqlmhrheqlm
VOLTE is working fine for me, should i install the latest update or not take the risk, I am worried about losing it after the update
ignore it, it only has voLTE fix, nothing else. Update when the new patch is coming out with google security update.
eqlmhrheqlm
Danishblunt
https://zentalk.asus.com/en/discussion/comment/221378#Comment_221378
thanx. hope this update will fix the problem for others
BPM
Rising Star II
Provider: T-Mobile
Country: United States
Provisions:
VoLTE: Yes*
Video Calling: Yes*
WiFi Calling: Yes*
*NOTE: All three sliders are enabled but greyed out (not sure if this matters).
What doesn't work:
Both VoLTE and WiFi Calling appears to work fine for me. Enabling video calling requests that I download the Google dialer app as the Asus dialer doesn't support it.
dgw
Provider: T-Mobile
Country: US
VoLTE Provisioned: Yes
Video Calling Provisioned: No
Wifi Calling Provisioned: No
I'm updated to 31.0210.0210.236
a_azizal9100g
I'm already update to latest software but still not showing in setting
