Sudden Drop in Battery Capacity
kamath_47
I have a 2021 purchased Rog3. Over the past 15 days the battery capacity has fallen sharply from 80% to 70%.
I am using AccuBattery Pro to track the battery health. Anyone else experienced similar phenomenon. Is this a genuine battery issue or something else.
I rarely use fast charge and charge generally from 20% to 80%.
Screenshot attached herewith for reference
4 REPLIES 4
HexHyte
Rising Star I
It also happened to me almost the same day!! sus
kamath_47
So I went ahead with battery replacement for the phone. The newly replaced battery's capacity is being indicated at 82% in Accubattery Pro. Is this normal. Shouldn't a new battery have a capacity of 90-95% atleast. If not 100%
Hi @kamath_47
I recommend reaching out to the service center you used for the phone battery replacement.
You can also make sure that you optimize your settings to preserve battery life.
https://www.asus.com/support/FAQ/1041327/
From where did you purchased battery is still rog phone 3 spare parts like battery, display, charger available in service centre I want to replace battery and purchase charger that too original
