Shortcut for slow battery charge
A555
Is there a way to set a shortcut somewhere to enable/disable slow battery charge and schedule charge without having the need to go through settings? I'd like to do slow charge during night and need fast charge during the day.
ARP_ASUS
Community Legend II
Yes you can. Tap on hold on homescreen => Select Widgets => Select settings => Once you place it on homscreen => It will ask you which particular settings sub menu you want to use => Select Battery.
