ROG Phone 3 power button issue after A12
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-11-2022 04:28 AM
Model Name: ROG Phone 3
Firmware Version: 31.0210.0210.236
Rooted or not: Not Rooted
Frequency of Occurrence: Daily
APP Name & APP Version (If your issue relates to the app): N.A.
After updating to Android 12, I have this persistent issue with the power button. It is unresponsive at times and occurs daily. I will press the power button to turn on screen or to check the time but phone will freeze and lag and the screen would only light up approximately 5 to 8 seconds after I had pressed the button. It occurs only when my screen is shut and I am trying to on the screen again.
I don't know what is causing this but it had been occuring since I updated to Android 12. I have tried to clear the cache and restarted my phone but it still occurs.
There is no problem with the power button physically and my best guess is it is some software issue.
Other physical button (volume) seems to work fine.
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2022 09:28 AM
@SangeYasha
Hello there,
After careful consideration, it may seem like this is a hardware issue. We recommend that you take your device to the nearset service repair center. We apologize for the inconvenience.
In the meantime, you could also temporarily enable “double tap” function to wake the phone up.
Thank you!
Hello there,
Thank you!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2022 02:59 AM
keren_ASUSHuh?!Hello there,
Thank you!
How on earth did you come to the conclusion its a hardware problem?!
@SangeYasha most likely problem with waking the device from sleep. Maybe some drivers or other pieces of software corrupted by upgrading to a12. A clean install of a12 should fix the issue again.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-16-2022 09:24 AM
Interestingly, my ROG3 ALSO is facing power button problems and it looks like it IS a hardware issue.
Does it mean that ROG3 was developed in such a way that hardware that's been used in it, has life expectancy of around 2-3 years?!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-17-2022 04:46 AM
