problem network sim card 1&2 after update 17.0823.2008.78
robustagundam
Model Name: rog phone 3
Firmware Version:17.0823.2008.78
Rooted or not: no
Frequency of Occurrence:
after 1 update 17.0823.2008.78 my phone always lost signal especialy simcard2 not detect the card
and i switch simcard 2 to simcard 1 and simcard that i put in simcard2 tray not geting signal
and there is notification telephony service that sim 2 not allowed
please fix this problem asap I have to work using both network
52 REPLIES 52
XKOMODOTCOM
Rising Star I
robustagundam
https://zentalk.asus.com/en/discussion/comment/121391#Comment_121391
no luck
ahahah emang dah for those who dare banget ini hp
Coba lagi bro, dan ikuti baik-baik.
Btw pakai provider apa emang?
XKOMODOTCOM
Rising Star I
stanislausadnanto
Ternyata beberapa hp baru lain pun mengalami masalah yang sama guys, jd cb kita tunggu aja
Iya bener, gak cuma ROG Phone 3 doang yang kena imbas dari mesin CEIR hampir penuh ini.
arbi_revo
Rizky.habibi
https://zentalk.asus.com/en/discussion/comment/121417#Comment_121417
Just try to set your Data Service Network into sim 2, and then switch to airplane mode about 5 minutes. You can switch on your network again and voila! Your signal will appear on both of SIM. But unfortunately the SIM 2 cannot be used for call, it just can be used for internet connection only
I did already Mas, but then i can't get 4g signal. It keep stays at H+ only. Is it happen to you also? or this phone just can't retrieve 4g on Sim 2?
Rizky_habibi
arbi.revo
https://zentalk.asus.com/en/discussion/comment/121424#Comment_121424
Make sure your preference setting already 4g/3g/2g. Soalnya gak bisa keduanya disetting 4g
arbi_revo
Rizky.habibi
https://zentalk.asus.com/en/discussion/comment/121713#Comment_121713
Iya, sudah juga ini mas. Tapi tetep yang sim 2 ga mau dapet 4g. Meanwhile kalo aku pindah (Tray nya) ke sim 1, ni kartu dapet juga 4g nya. Oke deh mas ntar gw coba lagi
