problem network sim card 1&2 after update 17.0823.2008.78
robustagundam
Model Name: rog phone 3
Firmware Version:17.0823.2008.78
Rooted or not: no
Frequency of Occurrence:
after 1 update 17.0823.2008.78 my phone always lost signal especialy simcard2 not detect the card
and i switch simcard 2 to simcard 1 and simcard that i put in simcard2 tray not geting signal
and there is notification telephony service that sim 2 not allowed
please fix this problem asap I have to work using both network
52 REPLIES 52
Rizky_habibi
arbi.revo
https://zentalk.asus.com/en/discussion/comment/121715#Comment_121715
Iya, sudah juga ini mas. Tapi tetep yang sim 2 ga mau dapet 4g. Meanwhile kalo aku pindah (Tray nya) ke sim 1, ni kartu dapet juga 4g nya. Oke deh mas ntar gw coba lagi
Coba akses *#*#4636#*#* terus pilih phone 1. Preference nya pilih LTE only.
khawer_ahsan
I am having the same issue, 2 days back i purchased Rog 3 global version 12gb/512gb version and using it in Saudi Arabia on STC network. Signal works with high speed on My old mobile but Rog 3 failed my expectations, sudden drop of signals every time, keeps connecting and disconnecting every 5 mins i have to keep toggling Airplane mode On/Off to refresh network signals, VoLTE not working on ROG3, everytime I call someone network switches from 5G/4G to H that results in bad call quality. Everytime when I have to go online I have to goto nearby WiFi to have a stable connection. Already Update to 17.0823.2008.78 but still the same problem. Already done Factory reset twice but still the same problem.
arbi_revo
XKOMODOTCOM
https://zentalk.asus.com/en/discussion/comment/121560#Comment_121560
Coba lagi bro, dan ikuti baik-baik.
Btw pakai provider apa emang?
ini tak coba signal nya berhasil muncul bang, cuman ga bisa dapet 4g. Tapi kalo q balik sim nya ke tray 1 bisa dapet 4g nya. Ada yang ngalami juga kah?
hermantan89
Rising Star I
Per Selasa, 6 Oktober 2020, setelah merestart ponsel, saya sudah mendapat signal dari SIM 2 gan.
Bagaimana dengan kalian?
robustagundam
XKOMODOTCOM
udah bro sesuai
pake telkomsel sama by.u sama2 telkomsel juga
yang satu untuk kerja yang satu untuk data
