PIN code required every day
eqlm2
Rising Star I
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
i have this annoying problem after the .98 update which is i have to put the PIN code once every day or every 24H.
before that i had to do that maybe once a week, understand that it is for extra security, BUT not every day.
is there any way to fix this issue
thanx
mohammed98221
This is not new to .98. Pin is required every 24hrs or if phone has been idle for 4hours. Try disabling face unlock. With fingerprint unlock you only need to enter pin every 72 hours.
