Passthrough power - how is it works?
kagdmhh
Model Name: Asus Rog 3
When I attach the charging cable to the phone it's charging, doesn't matter which port I use.
How can I activate passthrough charging/power which means the battery is not charging only the phone gets energy from the cable?
Or I misunderstood the reviews about the phone?
11 REPLIES 11
Jan_Darrel
kagdmhh
  1. Model Name: Asus Rog 3
In my understanding passthrough power when your battery reaches to 100% the power adapter which is charging the battery will directly go to the phone automatically bypassing the 100% battery. So the battery will act as a UPS (uninterruptible power supply) which i'm using in my Desktop Computer when you switchoff the power line adapter the battery will kick-in and supply the phone.
Anders_ASUS
Hall of Fame III
kagdmhh
What it does is that it only takes as much power as it needs to run the system. So if you're at 32% battery and enable passthrough power, then you will still have 32% when you stop gaming. The benefit with this mode is that it doesn't generate extra heat from charging the battery.
pawz110
Anders_ASUS
https://zentalk.asus.com/en/discussion/33686/passthrough-power-how-is-it-works
But how do you enable this on the phone?
Where is the settings for this?
Which port do I have to use?
Do I have to use the bundled 30w charger?
Anders_ASUS
Hall of Fame III
pawz110
https://zentalk.asus.com/en/discussion/comment/104522#Comment_104522
Sorry, too fast, didn't read 😉
If I'm not mistaking, this option will appear inside Game Genie while charging in a future update. Soonish
