My phone is having blackcrush issue and Asus haven't fixed it yet and they were working on Rog 5.
jaykesharwani9
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Why provide such pathetic support and product?
Why lying to users of Rog phone 3?
I am facing blackcrush issue and you haven't done anything about it.
12 REPLIES 12
palwinder_g
fpm2011
ROG 3 was using Wuhan Tianma display. (a China factory manufacturing mediocre but not flagship level display)
For ROG 5 the screen is upgraded to Samsung display (Zenfone 7 was using, rog 5 uses a newer generation calibrated for gaming)
There was no user reporting blackcrush issue at Zentalk Zenfone 7 forum.
I believe that the black crush problem also wont happen at ROG 5
If you can resell your ROG 3, switching to ROG 5 would be a wise choice~
Can you guarantee it buddy..... Whereas the asus people are quiet about this... Who are you to suggest buying new asus phones.....
ARP_ASUS
Hi jaykesharwani9,
Make sure you are on latest software version which is .131 if not, you can check by
Go to setting => System => About => Software information.
If you phone is on the latest software version and still if you are facing black crush,
Kindly visit the nearest service center:
https://www.asus.com/in/support/service-center/india
momeimada
Rising Star I
markovo
Don't worry, ROG 5 has black crush too. They never going to fix it, because it's not going to bring them any money. Not in ROG 3, nor in ROG 5.
ROG 5 uses display is from Samsung, so nope.
Danishblunt
Hall of Fame I
momeimada
https://zentalk.asus.com/en/discussion/comment/156706#Comment_156706
Sorry to burst your bubble but the Rog5 has black crush as well.
Danishblunt
Hall of Fame I
fpm2011
The Tianma display which has been used in the Rog2 doesn't support DC dimming to my knowledge but the Rog3 does. The zenfone is not using a samsung display, the zenfone uses a visionox OLED panel, I know this from the kernel sourcecode.
Also the Rog5 has black crush: Rog5 vs Mi 10
Blacks are quite crushed.
Not to mention the Rog5 is absolutely garbage when it comes to durability. Not only that but it seems the snapdragon 888 is also throttling according to LTT. Overall the phone was rushed and poorly designed.
