Is there a way or an option to activate the lower RGB LED next the flashlight on ROG Phone 3 ?
Gaurav0120
Respected Asus Management and my fellow friends, I bought my ROG Phone 3 about a month ago, and I haven't been able to find an option to activate the lower RGB light next to the flashlight. I am very well aware that, this can only be activated when the lighting Armor case is applied. But, what I wanted to know is that, is there any way, to activate it without that case. If there is now option at the moment, I request the software developers to please give us this option, as it is such a beautiful light, but has been disabled. Please enable this in the next FOTA 🙏🏻.
ARP_ASUS
Community Legend II
Hi Gaurav,
Yes, you are correct the same is only limited to Special lightning armor case and cant be used for anything else. Its a feature and that's the reason its present.
Gaurav0120
ARP_ASUS
Hi Gaurav,
So Sir, is there any possibility, that you people will enable this to work even without the lighting armor case, as it is such a brilliant feature but its potential has been limited to only light the case and not anything else ?
MV
Rising Star II
ARP_ASUS
Hi Gaurav,
Not a very good feature then if it just works for 1 and only 1 case which costs 3000 INR. Not sure what the designers were thinking.
