Is my battery Ok?
g4m3raddict
Model Name:Rog 3 Strix Edition
Firmware Version:
Rooted or not: Not
Frequency of Occurrence:
Used Accubattery for few days and got these results, my doubt is why is my battery capacity is not showing to full 6000mAh instead it's showing 5k something.
26 REPLIES 26
xihe
Rising Star II
Why are you using 3rd party app?
hermantan89
Rising Star I
Accubaterry is not accurate, because it has not been updated for a long time (last on January 2020).
But the actual numbers are in the range + - 10%.
doktoralbonista
No it isnt. I got 5950 mAh on same app.
g4m3raddict
xihe
I don't know any other way to check the capacity of the battery and I felt it was draining fast if I don't use power saver mode
