I'm facing battery drain issue while the phone is idle. It almost dropped 11% while idle
maneeshgowda17
Model Name:Rog phone 3
Firmware Version:18.0410.2109.172
Rooted or not: No
Frequency of Occurrence: regular after few days of usage
Regularly it drops by 4-5% but day before yesterday I kept the phone and slept, it was at 29 and by morning it had dropped to 18
I tried booting to safe mode and checked it had 3% drain
Please help
captainMAD
Yes, iam facing the same issue on rog 3 device. It's draining alot while using and what is the use of 6000mah battery or it just a gimmick tell us
Irene2_ASUS
Zen Master I
Hi @maneeshgowda17
Can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
maneeshgowda17
Irene2_ASUS
Hi @maneeshgowda17
Whenever the phone goes idle there is too much of battery drain but it is not visible here
