GPS not working right on Android 11
kpetrov
Model Name: Rog Phone 3
Firmware Version: last two a11 versions
Rooted or not: not
Frequency of Occurrence: non stop
Im using Maps everyday and I have a problem with location. It refreshes very, very slow and navigation is not usable.
I need to clear Google Play Services cache and storage every time I open Maps or other navigation app to work properly.
15 REPLIES 15
kpetrov
Lets see what happened in few days after some updates (Google Maps or other google services) ...
wayne_hbw
wayne.hbw
Just an update. I was trying to revert to A10 but didn't realized that it will factory reset. After then, it auto upgrade to A11 again.. zzz.
Been using for a few days now. The Google Map GPS is working well.
Ok. Problem comes back. We need an update.
p_porsch
wayne.hbw
Yeah. Had the same problem. You need to login into your wifi and then immediately deactivate wifi on your router or turn your router off. Because your phone won't load the update via mobile data.
I have 1Gb/s downstream and after 3 sec the phone already loaded 380MB from 1,2 GB. 😅
kpetrov
Last couple of days maps working well for me. I dont know , but I think this bug is fixed. How about on your phones guys?
p_porsch
ASUS just released a new update where the problem should be fixed. I'm from Germany and reported the problem with many logs and videos and so on. And so they were able to get an update. But not tested the new update yet because I still have one issue not solved. I think A11 made the ROG Phone 3 slower while gaming. And it gets hotter. Still waiting for feedback from ASUS.
Can someone test the GPS issue and give feedback here?
