Battery draining very quickly even not using the phone.
shambu694
Model Name:Rog phone 3
Firmware Version:
Rooted or not:no
Frequency of Occurrence:
We need you to solve this problem which has occurred after new update. Please release new update as soon as possible. Or please take this phone back and return our money because this phone is not worth of 50 K. And the black crush issue is worse not able to see anything in the dark videos. Phones which are cheaper then this have a better display.
7 REPLIES 7
MV
Rising Star II
nightmaster552
https://zentalk.asus.com/en/discussion/40842/rog3-batterylife
.99 update. Over 5 days battery.
U should share the screenshot as well to show that stand by time. Or else everyone will be wondering like I am.
Ohh my blind eyes. 3days stand by.
PH
Rising Star I
Battery drains more than 5 percent when kept idle overnight...
shambu694
ARP_ASUS
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
As you asked. This screen shot is after updating. 122 December update.
