Battery Drain issue on ROG 3
captainMAD
Model Name: Rog 3
Firmware Version: Android 11
Rooted or not: noo
Frequency of Occurrence: Every day
APP Name & APP Version (If your issue relates to the app): ideal phone simply draining and normal 60hz refresh rate.Normal day to day usage
Hello,what is the use of big battry used in rog 3
6000mah battry ?
Or it's a gimmick, and just for....
I have bought recently on dasarath flipkart sale ,it would be one month only.
fix this issue as soon as possible
21 REPLIES 21
captainMAD
Things are getting worst day by day in terms of battry
I kept phone idle for 8 hours,it drained upto 18%
And 1.no always on display
2.no screen wakeup on notification
3. No background process
Nothing
Why thes things happening??
Saifuddin
Zen Master III
captainMAD
Nothing
Apart from drain , everything else you complain about has to be enabled from settings and what do you mean by no background process just turn off super clean if your are having issues with appa in background,
Also have you tried factory reset to see if that fixes battery drain
Mccurty
I'm using ROG 3 for about a year now. Without having battery problems.
After updating to 2109.172 a few days ago, the battery is being drained so much faster. Before the update it was great and I was really satisfied with battery usage and performance. But now it's draining like a 3000 mah battery.
I'm sure this battery draining article which opened recently is because of the new update. So if you can give us a new one with the fix it's gonna be perfect. But please do it ASAP since rhe draining is so high that we can't really ignore it.
Thanks.
(the phone is not rooted and I haven't installed or changed anything on my phone from before the problem accursed and I've been facing it right after the update so I'm sure this is related to the update.)
ARP_ASUS
Community Legend II
Hi, captainMAD
Can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
