Battery Drain, bypass issue, and slow charging feature
bobbyw86
Model Name: Rog Phone 3 strix
Firmware Version: .78
Rooted or not: not
Frequency of Occurrence: sometimes
APP Name & APP Version (If your issue relates to the app): standby
Hi Asus team
Can anyone help to check does my phone has issue or not? Sometimes the battery drain really fast and sometimes it's look's fine
I read several thread and i read from @Anders_ASUS to try pcmark attach is the screenshoot from theapps. I also attas the battery consumption. So sometimes the the battery can last sometimes it really drain just by sitting there without me doing anything. Even with power saver mode on.
Oh ya i notice sometimes just light use not gaming can make the phone heat up.
Bypass not running also while gamming it's on but the battery keep charging
The slow charging also work strange. Last night when i charge i make sure to switch the mode on and the notification show took 4hour but, i think from just less than an hour the battery almost full(btw not using original charger does this impact the result?)
bobbyw86
Another one that i find out. For slow charging. I have conferences call at 8 and finish at 10. Before i charge at 8 battery arround 12% and when i'm done arround 10+ battery 86%. The charging indicator showing long charge but it keep updating the charge is gettinf short and short
