Battery drain after .182 update
rajpc381
The idle battery drain after the .182 update is just disgusting. My phone dropped from 86% to 64% while on standby within 7-8 hrs. The previous update has idle drain issue but this update takes it a level higher.... Please do something about it
ARP_ASUS
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
