Audio Jack not compatible
Model Name: Asu Rog Phone 3
Rooted or not: No
Problem: AudioJack, Convert Original Audio is missing. I bought a conver audio Jack. Not original but not compatible. and I need advice to look again for Audio Converter For ASUS ROG Devices
4 REPLIES 4
Danishblunt
Hall of Fame I
any type c to headphone jack adapter should work as the phone itself has a built in dac.
Saifuddin
Zen Master III
Danishblunt
No , that adapter also needs to have inbuilt dac to work i guess ,
I think oneplus adapter should work fine , though i haven't used it yet so confirm before buying it
Danishblunt
Hall of Fame I
Saifuddin
https://zentalk.asus.com/en/discussion/comment/161299#Comment_161299
Wrong. There is no 3.5mm dac in the adapter provided by asus nor the ones i use. Those do not work on my razer phone as it doesnt have a built in dac.
Gustav_ASUS
Community Legend III
@naufalzhafrans33 Most adapters should work fine, but you should always check for compatibility issues beforehand if you can.
