Android system consumes most of the battery
Droid
Please tell us some basic information before asking for help.
Model Name: Asus rog 3(India)
Firmware Version: 17.0823.2007.58
Rooted or not: Not rooted
Frequency of Occurrence: Always
APPName & APP Version (If your issue relates to the app): Android system
Android system is consuming most of the battery. I noticed this issue last 3 to 4 days. It is taking more than 30% of battery.
5 REPLIES 5
Лёха
Yes, and I have this.
ARP_ASUS
Community Legend II
Hey,
Noted your feedback seems the SOT is good though.
Can you tell me is it only occurring on .58 software version?
Every charging cycle you see the same?
Droid
ARP_ASUS
Hey,
Yes SOT is good. I started noticing this issue after .58 update. Before that Screen always used to come on top which makes sense since it will take most battery. It occurs in every charge cycle.
Droid
@ARP_ASUS I think using Netflix app increases Android system battery usage. I am posting screen shots before and after using Netflix. After using Netflix for 1.48Hr Android system usage went from 4 to 15.
Before using Netflix
After using Netflix
