Aero active cooler stops working for specific model of Sony headset
abheeshek_agarw
Model Name: Asus ROG phone 3. Non-tencent version
Firmware Version: 17.0823.2012.131
Rooted or not: No
Frequency of Occurrence: 100%
APP Name & APP Version: PUBG mobile(Runic)
As soon as I connect my Sony headset WH-1000MX4(either using 3.5mm jack or bluetooth), the aero active cooler fan stops after 5-10 secs
It is a problem with only this model, I have wired Sony MDR-XB550, it works fine with it. When I disconnect WH-1000MX4 and connect MDR-XB550, the fan starts working. I have even tried with Apple air pods 1 over bluetooth, and it works fine with it too.
Basic troubleshooting I have tried:
Reboot the device multiple times.
Disconnect / Reconnect bluetooth
Clear Cache of Armoury Crate
Attach / Re-attach multiple times
Allow device to cool down
It is an amazing Device you guys have built, but I would really like if I could use my 350$ headsets with it, which I just bought, and now quite let down due to this
Let me know what more info you need.
7 REPLIES 7
rogeriskira
Rising Star I
It has to be that the mic is somehow being used (There's a setting for the cooler to disable when mic is active). I currently have the WH-1000xm3 and I do not have these issues with bluetooth or wired. There isn't much difference between the two different headsets.
kim_levie_g
It has something to do with the option for the Aero cooler, you might want to disable the Fan to turn off while mic is running option.
abheeshek_agarw
Is this only applicable for Aero active cooler 2? I have seen threads online for these, but cannot find this option for me in three dots => Settings => Disable cooler when mic is ...
I have Aero active cooler 3, and ROG phone 3
Its upgraded headset, although built on mx3, there are hardware and driver upgrades too, which cannot be ruled out for causing issues
abheeshek_agarw
Update:
I just found the option "Disable fan when mic is active" in Console => Fan speed
And it was turned on 😓
Wondering why it still worked for airpods, but thanks for pointing it out guys. I will update if it does not work
