【Version】
17.2017.2006.429
【Model Name】
ZenFone Max Pro (M1) ZB602KL
【Release Date】
2020/07/02
Please download this version from ASUS official website.
【Release Note】
Android 10 upgrade.
Please be aware that installing this system image on a device removes all personal data from the device, so please remember to back up your data first.
This is the Android 10 AOSP developer version, so the user experience will be different from Android 9. If you are used to and prefer using Android 9, we recommend that you continue with the Android 9 version.
Updated Android security patch
Fixed fingerprint cannot be set issue
Fixed latest Android P image cannot upgrade to Android 10 issue
Fixed user can't hear low frequency sounds issue
Fixed fast charging not working issue
Fixed Arena of Valor without high frame rate mode issue
Improved sound quality at Media and notification sounds
Fixed Netflix no HD (widevine L3) issue
Fixed lock screen wallpaper issue if user sets different pictures for the wallpaper lock screen, and double-click to wake up
Fixed text display issue of APP name
Fixed VOIP call silent issue after opening "OK Google" in the voice assistant.
Fixed HD, HDR HD, High frame rate missing issue in PUBG
Fixed NFC not working issue after upgrading to the Android 10
