【Version】
16.2017.1905.065
【Model Name】
ZenFone Max Pro(M2) ZB631KL
【Release Date】
2019/05/20
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?【Release Note】
Android P upgrade
Upgrade April, May security patch
Fix Dark mode missing on: app drawer, pull down quick setting, long press on power key
Fix Overlapping observed on RSSI bar with Roaming Symbol and PDP Icon.
