TUF A15 FA506ii low CSGO fps + RAM upgrade
fAk3svk
System: Win 10 20H2
Battery or AC: Both
Model: TUF A15 FA506ii
Frequency of occurrence:
Reset OS: Yes
Screenshot or video:
Hello. I purchased this laptop few days ago (r5 4600h, 1650Ti 4GB, 8GB ram, SSD). I noticed that when playing CSGO my fps is around 70-120 (Ofic. MM, faceit, training with bots). I tried various FPS boost commands, setting the priority to high, uninstalling the game, even tried to disable/enable the services in msconfig, but nothing helped. I know that this laptop can do much more as I was getting about 200 fps on my 5 years old n551vw laptop (i5, 960m, 12gb ram). I've even updated the bios to 314 but it didn't help. The game is installed on the SSD. What do you think might be the source of the problem?
I was thinking that it might be the RAM (8GB CL22) but I'm not sure. I know that CSGO is a game that uses more CPU than GPU but I didn't think it would be a problem for the R5. Regarding the RAM, is it possible to get rid of the original 8GB ram and replace it with a single 16GB faster CL16 unit? I think I saw somewhere on the internet that the RAM is soldered and can not be replaced.
Thank you, hope you understand as my english isn't the best. Patrick.
32 REPLIES 32
anhquangno1
As i could see from my friend's laptop, it should be around 60 to 75 fps. We really have a big problem hẻre
fAk3svk
What graphic card does he have? I think it's near impossible to run FC4 on ultra with all nvidia functions turned ON with 1650Ti on 60 to 75 fps. FC4 needs a lot of VRAM and my gpu is only 4GB so I think the 45fps I've achieved is pretty impressing.
anhquangno1
Ok. I will check it later. We are having an exam this morning
anhquangno1
Hey dude, he really got 70 fps with gtx 1650ti. I found several videos on youtube which prove that you can get bette fps with 1650ti.
anhquangno1
He also can play red death redemtion with 60 fps. Come on gtx1650ti is not that weak as you thought
