TUF A15 FA506ii low CSGO fps + RAM upgrade
fAk3svk
System: Win 10 20H2
Battery or AC: Both
Model: TUF A15 FA506ii
Frequency of occurrence:
Reset OS: Yes
Screenshot or video:
Hello. I purchased this laptop few days ago (r5 4600h, 1650Ti 4GB, 8GB ram, SSD). I noticed that when playing CSGO my fps is around 70-120 (Ofic. MM, faceit, training with bots). I tried various FPS boost commands, setting the priority to high, uninstalling the game, even tried to disable/enable the services in msconfig, but nothing helped. I know that this laptop can do much more as I was getting about 200 fps on my 5 years old n551vw laptop (i5, 960m, 12gb ram). I've even updated the bios to 314 but it didn't help. The game is installed on the SSD. What do you think might be the source of the problem?
I was thinking that it might be the RAM (8GB CL22) but I'm not sure. I know that CSGO is a game that uses more CPU than GPU but I didn't think it would be a problem for the R5. Regarding the RAM, is it possible to get rid of the original 8GB ram and replace it with a single 16GB faster CL16 unit? I think I saw somewhere on the internet that the RAM is soldered and can not be replaced.
Thank you, hope you understand as my english isn't the best. Patrick.
32 REPLIES 32
anhquangno1
Ah. I forgot telling you to download Msi after burner and see how much percentage of your dedicated gpu is used when playing games. It is really important. Just follow some basic instruction to turn on on screen display and see how much of your gtx 1650ti is used when having a single channel 8gb ram. Our specs are the same. If you get about 60 to 70 % gpu used then we got the same problem bro. I will use this result to help asus tuf community in 🇻🇳 Vietnam.
Thank you very much!
fAk3svk
I've tried the msi after burner, followed the instructions but it's not working while ingame. I will try again and post the results. Btw I've ordered the ram, crucial 8gb 3200mhz 22cl. I literally can't find any 1.2v 3200 mhz lower than 20cl ram here in UK
anhquangno1
hm, it should be the same kind with the original ram stick.
😆 hope that will be ok
anhquangno1
https://www.youtube.com/watch?v=fdxnOUT7Pnc Here is how to set up msi after burner. Everything gonna be fine.
anhquangno1
Do not mess with the clock scale oryou will get into trouble.
