Mesh RT-AX3000 via ethernet LAN
HFJonkers
System: ??
Battery or AC: AC
Model: RT-AX3000
Frequency of occurrence: n/a
Reset OS: updated to latest firmware
Screenshot or video:
Detailed description:
I want to create a mesh network using two AX-3000 wifi routers. My home has a full ethernet cable network. If i connect both routers to the ethernet LAN network, will they detect each other to create a mesh network? Or do the routers need to be physically connected together (e.g run an ethernet cable from router 1 to router 2 bypassing my switch?
GEEK_ASUS
Rising Star II
Hi there,
Here we mainly discuss laptop related issues.
If you have issues regarding setting the mesh network, please contact local contact center for further support.
ASUS - Contact UsThank you.
