How can I fix problem g.co/ABH
netto_brown
Model Name:Asus Zenphone
Firmware Version:9
Rooted or not:
Frequency of Occurrence:
Cannot open phone as message says system corrupt and should not be relief upon. Says problem is g.co/ABH will not let me in
Can get to reboot screen tried factory settings nothing working
Falcon_ASUS
netto_brown
  1. Model Name:Asus Zenphone
  2. Firmware Version:9
  3. Rooted or not:
  4. Frequency of Occurrence:
@netto_brown
If the phone cannot enter the system normally, I would like to suggest you to bring back your mobile to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
