ZenWifi XD5 LAN port
yeowkm
i bought a pair of XD5 zenwifi router for my home.
when i setup the main unit, i noticed that the LAN port is showing public IP adderss when i connecte my laptop.
I have already connected WAN/LAN port to my telco ONT. Internet is working but LAN port still show WAN IP instead of the LAN subnet of 192.168.50.xx/24.
is there any settings for the LAN port?
WIFI clients is working fine using 192.168.50.xx/24 ip address.
10 REPLIES 10
jzchen
Zen Master II
If you open asusrouter.com in a web browser on the laptop does it go to ASUSwrt log in page of the XD5?
it does not goes to ASUSwrt.log.
what i get is you can't reach this page
Hmmm… can't reach this page
Check if there is a typo in asusrouter.com.
i can get Internet access when connect LAN port using laptop.
ping yahoo.com
Pinging yahoo.com [74.6.231.21] with 32 bytes of data:
Reply from 74.6.231.21: bytes=32 time=247ms TTL=40
Reply from 74.6.231.21: bytes=32 time=240ms TTL=41
Have you set up the 2nd XD5?  It might be waiting/looking for the other XD5 before acting normally.  (They support ethernet backhaul).
I think for the XD5 they did not set up the asusrouter.com, try 192.168.50.1 for the router log in page.  My apologies.
i did managed to setup the 2nd XD5 with XD5-1 LAN port to XD5-2 WAN/LAN port. after that i connect other devices to XD5-2 LAN port it works normally.
my question is how come XD5-1 LAN port cannot be used as LAN. i connect laptop to this LAN port cannot use as client.
192.168.50.1 from XD5-1 LAN port - will try again.
