VPN IPSec Client / Fusion on RT-AX5400
DesertDrive
Hello, I have an RT-AX5400: https://www.asus.com/us/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax5400/
It is capable of being a VPN IPSec server. It appears it cannot be a VPN IPSec client.
I have looked under the "VPN Fusion" tab. The options as a client are:
* OpenVPN
* WireGard
* L2TP
but IPSec is excluded.
Is this correct? Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Aureliannn_ASUS
Hi @DesertDrive ,
Thank you for your inquiry.
After confirmation, the VPN client function of the RT-AX5400 model does not currently support the IPSec protocol.
Therefore, you will not find IPSec-related settings in VPN Fusion.
RT-AX5400 - Tech Specs|WiFi Routers|ASUS Global
Thank you for your cooperation.
Aureliannn_ASUS
Hi @DesertDrive ,
thank you
