01-04-2025 06:46 PM
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
02-10-2025 06:02 PM - edited 02-10-2025 06:05 PM
@cowhow Ah, thanks. Found it in another thread.
02-10-2025 07:52 PM
It brought my CPU usage down to respectable levels but didn't do anything for thermal errors. I understand from @Aureliannn_ASUS that 37803 was targeting CPU usage so I assume another build is coming for thermal errors.
02-10-2025 08:05 PM
Yeah, thermal errors continue to persist and I'm having impacts to speeds. Fingers crossed they'll get it together. I really like this router's features. I replaced a TP-Link with it that was doing just fine.
02-10-2025 08:06 PM
Went out to dinner and came back and this first time I have seen Uptime over 2 hours.
02-11-2025 08:54 AM
I too have been running the newer 3703 firmware. Router is more stable but I still have thermal issues. I have since moved the router to another part of my house replacing an older AX82U. It seems to run ok with a smaller load on it. Shame that it can't be my main router....Another AX82U drives everything, xbox, PS5, TVs, and 6 amazon echos. Guess when Asus gets this solved I'll move to be my main router. Until then, I have to settle for wifi6....
