Latest Firware: RT-68U
Kazz5
All I can find on the Drivers & Utilities page are 2 utilities. When I try to update the firmware from within the router's software it says it can' t reach ASUS' servers. But I can find no firmware file for a manual upload. Can someone help me find the latest firmware for the RT-68U?
Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
Aureliannn_ASUS
Hi @Kazz5 ,
based on your issue, may I ask whether your product model is RT-AC68U or RT-AX68U
After searching, both of these models have firmware versions displayed on the official website, and they can be downloaded without any issues.
Please double-check that you've entered the correct product model. Thank you.
Aureliannn_ASUS
Hi @Kazz5 ,
Kazz5
Thank you! I looked more thoroughly. The page I found the first time only had manuals. Thanks again!
