08-15-2024 09:24 AM
So, I've got the ASUS RT-AX86U router, running Version: 3.0.0.4.388_24243. I'm trying to avoid the hassle of manually excluding a single device. I've set up a VPN server profile under `VPN -> VPN Fusion` and made it the default connection for all devices. Now, I want this setup to apply to every device except for one — my PS5. Is there an easy way to do this from the GUI?
What I Tried
I'm attempting to set up a dummy profile and assign my PS5's IP to it, layered on top of the VPN profile. The idea is for all connections to go through the VPN, except for the PS5, which would be excluded by the second profile. However, I'm prompted for a private key to set up the second profile. Since it's just a dummy profile, is there a way to create one? I need help achieving this.
08-16-2024 08:21 AM
I don't know the encoding but isn't that just one enormous prime number? You can get one here:
