Tuesday
Hello, don't know if anyone has tried this but when I turn on 2.4 Ghz band and 5 Ghz using the 6 Ghz as a wireless backhaul, all my wifi connections seem to want to use only 2.4 Ghz. Even if I'm 2 feet away from Router or the AiMesh 2nd node, same thing. Max speed is 150 mbs.
As soon as I turn off 2.4 Ghz band, all devices use 5ghz and hit my ISP max Mbs of 300.
Is this an Asus bug in their firmware? With my old router (Linksys) it would only switch to 2.4 ghz if you were far away from router. To me that is the normal operation but this ET9 doesn't do that.
Any ideas?
