compare
Taylor_revi
Hey,
I wanted to know what people think is a better modem. I have been looking into getting a new modem and wanted to see what some people thought was better. I have been looking at the DSL-AC88U and the DSL-AX82U; I want to see what people think is better.
Thank you for any help you can provide, appreciate it.
Kind regards, Taylor Revi.
Aureliannn_ASUS
Hi @Taylor_revi ,
based on your question, both the DSL-AC88U and DSL-AX82U are high-quality modem routers, but they have some differences in terms of features and specifications. To determine which one is better for you, it depends on your specific needs and preferences.
You can refer to the following product specification.
DSL-AC88U|Modem Routers|ASUS Global
DSL-AX82U|Modem Routers|ASUS Global
Ultimately, the best choice depends on your internet plan, the devices you have, and your budget. Consider the features that are important to you and choose the one that fits your needs best.
