ASUS ZenWiFi AX (XT8) compability?
JockeSve
What ASUS routers can be added to ZenWiFi AX (XT8) as Mesh-nodes except another XT8?
Can't find a "compability list" anywhere...
6 REPLIES 6
Start ower:  Reset both (toothpick under the device), keep NW-cable connected between devices.
BTW: Is cable correctly connected: LAN port on "router" to  WAN-port on "node"?
I have done the hard reset holding the WPS button. Connect the first one no problem had it sitting on 5g backhaul was setting up the other device and it will only connect if it's wired don't get an option to go wireless and will not update to the new firmware. Problem is I bought them second hand seen them working wirelessly but when the guy reset them it have screwed one up. So has to be ASUS but can't see them helping. 😭
