Amount of Wifi Devices that can Connect to RT-AX59U and RT-AX53U
DBarbedo
Looking to find out how many Wifi devices can each of these Asus routers provide simultaneous connection:
- Asus RT-AX59U
- Asus RT-AX53U
Aureliannn_ASUS
Hi @DBarbedo ,
specific information regarding the maximum concurrent connections for the Asus RT-AX59U and Asus RT-AX53U routers cannot be accurately provided with a numerical value.
The capability to handle simultaneous connections is influenced by router hardware specifications, firmware, additional features, and the current usage environment.
However, you can choose the product that best suits your needs based on the specifications of the two routers.
You can refer to the following product specification:
RT-AX59U|WiFi Routers|ASUS Global
RT-AX53U|WiFi Routers|ASUS Global
Thank you for your support.
Hello Aureliann.
Sorted. Thanks
