AI Mesh - RT-BE88U with ZenWifi BT8 (ethernet backhaul) - Dual band vs tri band
djhifi
As the title says, I have a RT-BE88U and I'm thinking about buying ZenWifi BT8 and configure the AI Mesh as Wired Etherenet Backhaul since I have several wire connections throughout the house.
Question: Since the main router is dual-band and ZenWifi BT8 are tri-band (both WiFi7), will the ZenWifi BT8 lose the 6ghz band if it's connected as node, even tough it's using the wired backhaul?
Aureliannn_ASUS
Hi @djhifi ,
Thank you for your inquiry.
Regarding the issue you mentioned about the ASUS RT-BE88U not being able to use the 6GHz band when used as an AiMesh node, we would like to provide you with a detailed explanation:
The ASUS RT-BE88U only supports 2.4GHz and 5GHz bands. Since AiMesh nodes synchronize with the settings of the main router, if the main router itself does not have the ability to synchronize the 6GHz signal to the nodes, it is normal for the nodes not to have the 6GHz band.
If you wish to use the 6GHz band in your network environment, we recommend that you set the ASUS ZenWiFi BT8 as the main router. This way, all devices connected to the network (including AiMesh nodes) will be able to use the 6GHz band.
If you encounter any issues during use or need further assistance, please feel free to contact us.
Thank you for your cooperation.
djhifi
Thanks for your answer, and if I configure as standard access point it would work, correct?
Regarding this, is there any ETA as to when the ZenWifi BD5 will be available in Europe?
