06-14-2024 04:04 PM
Asus RT-AX86S router. I have 2 iPads with iOS 17.5.1. They are set up exactly the same as are the settings on the router the same. 1 iPad can connect to my wireless and 1 iPad can't connect when Time Scheduling under the Parental Controls area is enabled. If I disable the scheduling on the one that originally could not connect it is then able to connect, but I lose the time scheduling feature.
Any suggestions, solutions, etc.
Thanks...
Solved! Go to Solution.
06-15-2024 05:39 AM
There are other reports on the ROG (Gamer focused) forum of similar issue. If the router is under warranty I would contact ASUS support. Also try to send Feedback though the router:
Under Advanced Settings -> Administration -> Feedback (tab).
06-15-2024 05:39 AM
