Somebody have efi for downgrade thunderbolt nvm to 31 for rog strix z790-i motherboard?
polywaves
I have problem with connecting my uad apollo twin tb2 with apple tb2 to tb3 adapter, as i knew it's nvm version trouble. My current version is - 38, i need version 31 for correctly working.
I tried send message to support mail but i can't provide serial number cause it always incorrect format
may be somebody can help me?
Thanks!
Jiaszzz_ASUS
Hello @polywaves
Thank you for reaching out to us.
As verifying the specifications requires confirming the serial number, which should not be shared publicly, I have DM you earlier.
Please check your messages and provide the requested information at your convenience.
