04-20-2024 05:19 AM
Would welcome a bit of advice if anyone has any ideas.
I'm using the ProArt Z690 board with a processor that includes Intel UHD Graphics 770. I'm currently running a 4K monitor through HDMI. I want to run a second, similar monitor and planned to use USB-C for the second one. The user manual suggests (I think) that it should work using the USB-C 1 socket. I've set the BIOS for multiple monitors.
Windows does not detect a second monitor and the second monitor does not detect any input on USB-C.
Should this work or am I doing something stupid?
Many TIA.
Solved! Go to Solution.
04-28-2024 08:28 PM
Hello, @GazzaB
We apologize for any inconvenience caused by the delayed response.
May I inquire if you are using a "USB-C to DisplayPort" adapter cable to connect to the monitor?
04-29-2024 02:36 AM
Thanks for the reply. Yes, I finally found the note in the manual and got an adapter.
04-28-2024 08:28 PM
Hello, @GazzaB
04-29-2024 02:36 AM
