What adapter is available to mount a Model 166B monitor to a versa pattern
rzietz
The ASUS monitor Model 166B has a tripod mount: What is the thread type and size? for the 1/4 inch screw hole in the back of the monitor and What is the maximum length of that screw?
Aureliannn_ASUS
Hi @rzietz ,
based on your question, we have introduced the ZenScreen Stand MTS02D, which allows users to install it on a monitor. You can find detailed installation instructions in the video below. Thank you.
https://youtu.be/9EUB5qAgTXY
[LCD Monitor] ASUS ZenScreen Stand MTS02D support model list & install mount stand method | Official...
Check and watch this video to know how to install ASUS ZenScreen Stand. Visit our ASUS Support site for more exclusive information https://www.asus.com/support/FAQ/1049834 #asus #zenscreen
rzietz
Thank you for your reply; however your response doec not answer my questions regarding the thread size of the 1/4 inch whole.  Inother words, hoe many threads per inch  and then the depth of the i/4 inch whole is it 1/8 inch deep or 1/4 inch deep?  Please review and let me know; Thanks for your nefforts.
