How to repair graphic card ?
ahmedbloshiee
I'm facing trouble using my graphic card . Should I buy new one or this one can be repaired perfectly ?
Aureliannn_ASUS
Hi @ahmedbloshiee ,
based on your issue, could you please specify which graphics card you are currently using? Additionally, I would like to understand the issue you are encountering in more detail.
Could you kindly provide a detailed description of the problem you are experiencing? Furthermore, have you attempted to update your graphics card drivers? If so, has this helped in resolving the issue?
Your cooperation in providing this information is greatly appreciated as it will allow us to better assist you in resolving the problem. Thank you.
