FAQBot
Community Manager
Community Manager
[ZenWiFi AX Hybrid]What should I take care of when using PLC Network as Mesh Backhaul?
Make sure XP4 connects within a circuit. If you put the router and node on different volt circuits, there is no path in the breaker panel to connect them. The signal would have to travel out of your house to the transformer on the electric power pole or connect through a 220-110 volt box substation circuit. HomePlug PLC link is unlikely workable, and if it does, the performance will be significantly degraded.
Generally, HomePlug signal can be used across fuse boxes or circuit breakers. Few kinds of circuit breakers or fuse boxes that implement high-frequency filtering design can weaken the PLC communication. For the special fuse box, the electrical panel also could act as a cross-phase coupler, make powerline signals “couple” or "radiate" across the electrical service panel's circuit breaker bus bars. In most cases, they have little influence on the communication of PLC.
For more product information, please refer to ASUS ZenWiFi AX Hybrid (XP4).
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link
Version history
Last update:
‎01-29-2024 05:18 PM
Updated by:
Contributors
