FAQBot
Community Manager
Community Manager
[Wireless Router] Wireless Router Frequently Asked Question (FAQ)
Problem CategoryProblem itemFAQ link
Router FirmwareFirmware UpgradeHow to update the firmware of your router to the latest version
How to update the firmware of your router to the latest version via ASUS Router App
How to update firmware of my AiMesh node
Firmware upgrading failsHow to use Rescue Mode (Firmware Restoration)
Reset the routerStandard ResetHow to reset the router to factory default setting
Hard Factory ResetWhen Standard Reset Isn’t Working: Hard Factory Reset - Models list
Router boot relatedRebootHow to Reboot your ASUS Router
Automatic restartHow to set up an ASUS router to automatically restart at specific times
Router restarts automatically on a regular or irregular basis
No Power/No BootASUS router or adapter is No Power/No Boot/Power LED is not ON
Enter routerLogin to Router(Web GUI)How to enter the router setting page(Web GUI)
How to log in ASUS router via Telnet
How to enter the Access Point(AP) mode settings page (WebGUI)
Login to Router(ASUS router app)How to set Passcode/Touch ID/Face ID for ASUS Router App login on iOS/Android
How to manage multiple ASUS routers by ASUS router app
How to bind trust account to my ASUS router
Access the router from the WANHow to set up ASUS wireless router to access WebGUI/Router App from WAN
Find the IP address of router
(ASUS Device Discovery)
How to use ASUS Device Discovery to find the IP address of ASUS router
Router's username and password problemHow to change ASUS Router login name and password
I cannot log in to my ASUS router's Web GUI/App using my username and password
Router Internet connection settingsInternet connection setupHow to use the QIS (Quick Internet Setup) to set up Router ? (Web GUI)
How to set up ASUS Wi-Fi router via ASUS Router App? (QIS, Quick Internet Setup)
How to set up an Internet Connection?(WAN connection types)
Change router operation modeHow to set up repeater mode on ASUS Router
How to set up media bridge mode on ASUS Wireless Router
How to set up operation mode- Access Point(AP) mode
Dual Wan setupDual WAN introduction and setup
How to configure the Auto Network Detection while enabling the Dual WAN?
Plug, Share & Surf: Turn Your ASUS Router into a 4G/5G Hotspot Instantly (4G / 5G Auto Mobile Tether...
WAN AggregationHow to enable WAN Aggregation on ASUS Router
Internet connection issuesHow to fix internet acess failure when using router
Range ExtenderConnection setup[Range Extender] How to Set Up ASUS Repeater with ASUS Extender App
[Range Extender] How to set Repeater mode on the ASUS wireless range extender?(WebGUI)
[Range Extender] How to set up Access Point(AP) mode on ASUS range extender device
Go series routersMulti-function buttonHow to setup multi-function button on Go series products
What is Home/Travel mode? How to configure
WISP modeWhat is WISP (Public WiFi mode) and how to setup
Wireless settingsModify wireless name and passwordHow to modify Wireless(WiFi) Name and Password in ASUS Router
What can I do if I forgot Wireless(WiFi) password
share your WiFiHow to share your Wi-Fi with family and friends
Modify wireless channels / DFS channelsHow to fix wireless Control Channel
What is DFS (Dynamic Frequency Selection) and how does it work on ASUS router
WiFi connectivity issueHow to fix random disconnection when wireless router or Range Extender is in repeater mode
How to fix Wi-Fi disconnection?
Wi-Fi Network Is Not Showing UpHow to Enable/Disable/Hide my ASUS router’s WiFi signal
Troubleshooting - Computer(WiFi device) cannot find the WiFi name(signal) of ASUS router
WiFi 7 Wireless RouterIntroduction[Technical Sharing] Wi-Fi 7 Introduction
MLO setup[WiFi 7 Wireless Router] What is MLO (Multi-Link Operation) and how it works
CompatibilityWhich ASUS and ROG products support WiFi 7
How to ensure WiFi 7 router compatibility with existing ASUS router and connected devices
Guest networkGuest network setupHow to set up Guest Network
Guest Network ProIntroductionWhat is Guest Network Pro
Guest Network Pro setup[Guest Network Pro] How to set up Guest Portal
[Guest Network Pro] How to set up Kid's Network
[Guest Network Pro] How to set up IoT Network
[Guest Network Pro] How to set up VPN Network
[Guest Network Pro] How to set up Guest Network
ASUS Smart home masterIntroductionWhat is Smart home master
ASUS Smart home master setup[Smart Home Master] How to set up Kid’s Network
[Smart home Master] How to set up IoT Network
[Smart home Master] How to set up VPN Network
Connection speedconnection stableTips to keep network connection stable
Wired connection speedHow to check the wired connection speed and network cable specifications for ASUS Wireless Router
Wireless connection speediPhone/Android phones are slow to connect to the router wireless (Wi-Fi) network
How to improve wireless speed by setting Channel Bandwidth in Wireless Router
How to improve Wi-Fi Connection
Quality of Service (QoS)How to check if the ASUS wireless router supports Adaptive QoS
How to enable the Website History feature in ASUS Router
How to set up Adaptive QoS - Bandwidth Limiter
AiMeshIntroductionAiMesh 2.0 Web GUI - Introduction
AiMesh settingHow to setup AiMesh system (Web GUI)
How to setup AiMesh system (ASUS Router APP-Android)
How to setup AiMesh system (ASUS Router APP-iOS)
How to setup ZenWiFi AiMesh system (Web GUI)
Ethernet backhaulHow to set up ASUS AiMesh or ZenWiFi Mesh Ethernet backhaul under different conditions (Advanced set...
Can I set up wired connection between AiMesh routers (Ethernet backhaul)
What is Ethernet Backhaul Mode/Backhaul Connection Priority in AiMesh System and how to set up in di...
Connection-relatedHow to bind my device to one specific AiMesh router or AiMesh node
Can I assign a preferred Uplink AP in an AiMesh system
How to Improve the Signal Quality between your AiMesh Router and AiMesh Node
LED IndicatorsLED switchHow to turn ON/OFF LED light of ASUS AiMesh router and AiMesh node (ASUS Router App)
LED color definitionHow to judge the current status of ZenWiFi Series Router from LED color
What is the meaning of the color of 4G-N12 LTE LED indicator
LED abnormalityHow to fix when ASUS router’s power LED flashing
How to fix when ASUS router’s WiFi LED light is not on
How to fix when ASUS router’s WAN LED acts abnormally
External USB disk Connect External USB diskHow to monitor your USB hard drive on ASUS Router
External USB disk detection failureHow to fix USB drive is not detected on ASUS router
FTP serverFTP server setupHow to set up Servers Center - FTP Share
FTP server is not accessibleWhy I cannot use windows file manager or web browser to access ASUS router FTP
Port ForwardingPort Forwarding setupHow to set up Virtual Server/Port Forwarding Rules on ASUS Router
VPN settingsVPN server
(PPTP / OpenVPN / IPSec VPN / WireGuard VPN)
How to set up VPN server/VPN client on ASUS router and connect using different devices
VPN client
VPN Fusion
Instant Guard
Third-party VPN services
(Surfshark / NordVPN / CyberGhost)
IPv6IPv6 setupHow to set up IPv6 in ASUS Router
LANLAN IPHow to change LAN IP on ASUS Router
DHCP serverHow to set up DHCP Server on ASUS Router
Router securityRouter securityHow to make my router more secure
AiProtectionAiProtection – Internet security and WiFi protection
How to set Network Protection in ASUS Router
Parental control setupHow to set up Parental Controls?(WebGUI)
How to set up Family(Parental Controls) via ASUS Router App
How to set up One-Tap Safe Browsing (Parental Controls) via ASUS Router App?
Devices connected to the routerHow to check the information of devices connected to ASUS router
How to delete an offline device
How to set up Wireless MAC Filter on ASUS Router(WiFi Deny List)
FirewallFirewallIntroduction of Firewall on ASUS router
How to set up IPv6 Firewall
Keyword FilterHow to set up Keyword Filter in ASUS Router
URL FilterHow to set up the URL Filter - Black/White List?(Firewall)
Network Services FilterHow to set up Network Services Filter in ASUS router
DDNSDDNS setupDDNS introduction and set up
How to remove the registered ASUS DDNS hostname in the router
How to transfer ASUS DDNS to new device
Software/ Hardware relatedAiMesh supported modelsWhat models of router / Range Extenders support AiMesh
ASUS Router APP supported modelsWhat models of ASUS routers support ASUS Router App
IFTTT supported modelsWhich ASUS router models support IFTTT
Instant Guard supported modelsWhat ASUS routers do support Instant Guard
Compatibility listASUS Router 3G/4G USB Adapter Compatibility List for ASUS wireless routers and DSL modem routers
ASUS Router Plug-n-Share Disks Compatibility List
Version history
Last update:
‎10-07-2025 03:38 AM
Updated by:
