[Windows 11/10] Sound settings and Volume Mixer
Please go to the corresponding instruction based on the current Windows operating system on your computer:
Windows 11 operating system
- Type and search [Sound settings] in the Windows search bar①, and then click [Open]②.
![](https://kmpic.asus.com/images/2022/03/01/0fa69a37-6581-4e5e-a657-61ee05ff92ca.png)
- In Sound settings, you are able to choose the Output device③ (such as internal speakers, external speakers, or headset) and the Input device④ (such as internal microphone, external microphone, or earphone).
![](https://kmpic.asus.com/images/2022/03/01/299bd1e1-d956-4473-8286-9cc4b6e0ba31.png)
If the speaker icon of master volume is
, it means your computer is at mute mode. Click the speaker icon again to turn the volume on.
![](https://kmpic.asus.com/images/2022/03/01/247420d7-9df0-471c-9357-2a4ee492505c.png)
- Getting to use Volume Mixer. Right-click [Speakers icon] on the taskbar⑤, and then select [Open volume mixer]⑥.
![](https://kmpic.asus.com/images/2022/03/01/d7a3fbc5-7ab6-4efc-857a-26a4b6ccbed2.png)
- In the Apps filed, by dragging the slider to adjust volume for each app⑦.
![](https://kmpic.asus.com/images/2022/03/01/9546643a-3ee7-4afd-b064-1cc540e97e34.png)
If the speaker icon of the app is
, it means the app is at mute mode. Click the speaker icon again to turn the volume on.
![](https://kmpic.asus.com/images/2022/03/01/5dddf610-60b5-4ffe-80b0-b060e42d9c5d.png)
Windows 10 operating system
![](https://kmpic.asus.com/images/2021/02/25/bab01cad-d106-4f1f-a60c-7d097daa1093.png)
- In Sound settings, you are able to choose the output device③ (such as internal speakers, external speakers, or headset) and the input device④ (such as internal microphone, external microphone, or earphone).
![](https://kmpic.asus.com/images/2021/02/25/9a66359b-f105-4079-9140-79589f68ecef.png)
![](https://kmpic.asus.com/images/2021/02/25/f81b0f33-676b-40e9-ab4a-647feed61111.png)
- Getting to use Volume Mixer. Right-click [Speakers icon] on the taskbar⑤, and then select [Open Volume mixer]⑥.
![](https://kmpic.asus.com/images/2021/02/25/18c0d019-353b-4abc-94f9-7ca5bb315ab8.png)
- In Volume Mixer, by dragging the slider to adjust volume for each app⑦.
![](https://kmpic.asus.com/images/2021/02/25/9f6b83c6-6456-4366-89fe-ce280d6c4f10.png)
![](https://kmpic.asus.com/images/2021/02/25/da9cb9a4-356c-4cbe-b0ef-ad83b4ee2cd9.png)
